whiteboarder Posted March 28, 2005 Report Posted March 28, 2005 is it possible to fix a stator i have an aftermarket stator and it is no longer producing spark the timing plate came loose and the stator rubbed a little on the flywheel. do you think its fixable or should i just replace it. Quote
fastbanshee4u Posted March 28, 2005 Report Posted March 28, 2005 is it possible to fix a stator i have an aftermarket stator and it is no longer producing spark the timing plate came loose and the stator rubbed a little on the flywheel. do you think its fixable or should i just replace it. 345961[/snapback] I have fixed several but not fun. you may be better off to call ricky stator. Quote
willnegus Posted September 1, 2007 Report Posted September 1, 2007 I have fixed several but not fun. you may be better off to call ricky stator. did you rewind your own stator, i just finished rewinding mine it took 9 hours, not sure if it worked because it still wont start, the reason i rewound it is because i broke the original windings, so i reound it myself, is it even possible for it to work Quote
willnegus Posted September 1, 2007 Report Posted September 1, 2007 I have fixed several but not fun. you may be better off to call ricky stator. does anyone rewind your own stator, i just finished rewinding mine it took 9 hours, not sure if it worked because it still wont start, the reason i rewound it is because i broke the original windings, so i rewound it myself, is it even possible for it to work Quote
David Keith Posted September 2, 2007 Report Posted September 2, 2007 is it possible to fix a stator i have an aftermarket stator and it is no longer producing spark the timing plate came loose and the stator rubbed a little on the flywheel. do you think its fixable or should i just replace it. If you call Ricky Stator & get their ship to address, they will test it, fix it or replace it if need be for a fair price. I have sent parts there & they did not try to sell me replacement pats that were not needed. They are honest. That's my story & I'm sticking to it. Quote
letsgetthisdone Posted September 3, 2007 Report Posted September 3, 2007 yup, i had a ricky stator fall apart on me and they payed shipping for me to send them the ruined stator, and they sent me a new free of charge...i would never hesitate to buy from them again. Quote
blowit Posted September 3, 2007 Report Posted September 3, 2007 is it possible to fix a stator i have an aftermarket stator and it is no longer producing spark the timing plate came loose and the stator rubbed a little on the flywheel. do you think its fixable or should i just replace it. If you can pinpoint the leakage area where the laquer coating is rubbed off the wiring, you can use liquid polyurethane to coat the wiring and repair the damage. This can often be done instead of rewinding the stator. If rewinding is needed, I recommend sending it in as it can take some time if not experienced with it. Brandon Quote
