01bansheefox Posted March 25, 2005 Report Posted March 25, 2005 Heard some people talking about it just slows you do, they just pin it and shift. Quote
BansheeBoy17 Posted March 26, 2005 Report Posted March 26, 2005 I rarely ever use the clutch while im riding ... period. Only times I do is out of a turn/berm ... starting, or shifting. Oh, and when im in the air and i hit the back brake, cause if not , the quad dies, and all goes silent while your in the air then BAM you smack the landing. I found that out. So now i hold the clutch when i hit the back brake Quote
ator Posted March 28, 2005 Report Posted March 28, 2005 Heard some people talking about it just slows you do, they just pin it and shift. 344775[/snapback] I have been ridding for quite some time now (almost 20 years) and with the exeption of starting, I very rarely use the clutch. Quote
H250RHATER Posted March 28, 2005 Report Posted March 28, 2005 I have been ridding for quite some time now (almost 20 years) and with the exeption of starting, I very rarely use the clutch. 346012[/snapback] tru also if theres a tight corner and with the yamascrap trans i alway's have to use it to shift Quote
01bansheefox Posted March 29, 2005 Author Report Posted March 29, 2005 And how does this work on your tranny by not using the clutch? You need to replace it quite offten? Quote
postal Posted April 7, 2005 Report Posted April 7, 2005 yeah, how often do you need to replace the tranny if you dont use the clutch? Quote
tats4life Posted April 7, 2005 Report Posted April 7, 2005 only on the start....just slam the shifter...i never had to replace anything tranny wise except a bent shift shaft. Quote
Minkia38 Posted April 15, 2005 Report Posted April 15, 2005 I almost always use a clutch, but the bears are lined up so nicely, that Ive heard you dont really need to.... but its not too hard to pull it in..... Quote
crbanshee Posted April 21, 2005 Report Posted April 21, 2005 i use the clutch alot in the desert races..if you feather it right you can use it like a lower gear with out having to shift..I.E. pulling up into a tight wash or out of a wash rip on the clutch and it will bring the banshee right into the power band and shoot you out like a bullet..it takes some getting used to but once you learn just how and when to do it you will love it....a great time to do it is right as you start to pass another rider on the track be it a mx track or open desert..not only will it sling shot you right past them but it kicks up just enough dirt to cause them to slow down a bit and make the paass stick.. Quote
