'SheeRider07 Posted March 24, 2005 Report Posted March 24, 2005 (edited) Well, I am going to be buying a new quad soon and I am pretty sure I wanted a Banshee. I always wanted one ever since I saw and heard them and now I can finally get one. Anyways, I will more than likely buy a used one with a couple mods like pipes, silencers, etc that has not been beat and is in pretty much good shape. Do you think it will be hard to find a modded, non beat Banshee that is pretty much "like new?" Also, how much should I expect to pay for a Banshee from the year 2001 or newer that is like new with a couple mods? Somewhere around $3,500? Anyways, the type of riding that I will be doing will be some trails, mainly open trails that you can go fast on most of the time, depending on how busy that they are. I also like to hill climb a lot and jump. I will be going to MX tracks every so often as well. I also like to wheelie, how does a Banshee wheelie? As far as maintance, what do I have to do to it? Anything I should watch for? Also, if I do the riding that I mentioned above, about how often do you think I have to rebuild it? I always hear people saying that Banshee's are so un-reliable and blow up left and right. This is what is pretty much keeping me from buying one, is this true? Also, how is the power on it compared to a Z-400, Raptor, and Predator I will be modding it out as well like pipes, silencers, bumper, nerfs, +2 a-arms, +4 axle, YFZ450 shocks, etc. Thanks for the help. P.S : I am moving up from a modded 400EX bored out to a 416. Edited March 24, 2005 by 'SheeRider07 Quote
white trash Posted March 24, 2005 Report Posted March 24, 2005 As far as maintance, what do I have to do to it? Anything I should watch for? Also, if I do the riding that I mentioned above, about how often do you think I have to rebuild it? I always hear people saying that Banshee's are so un-reliable and blow up left and right. This is what is pretty much keeping me from buying one, is this true? 344564[/snapback] Banshee's are just as reliable as any other quad, and actually require less manitainence IMO. When it comes time all you have to do is bore it and get a piston kit. No valves to adjust, and all the other shit that a thumper has. Doing a top end rebuild would probly cost less becuase of this as well. Shees have a bad rep about blowing up because people dont know how to take care of it... jet it wrong or whatever. Just make sure you check the compression before you buy it... should be about 115-125 per side, much lower than that and you will need a new top end. Take care of it and it will take care of you, just keep it jetted properly, and the oil changed, and dont look back (unless you want to see how far ahead you are of the 4 strokes) Quote
banshdog Posted March 24, 2005 Report Posted March 24, 2005 Also, how is the power on it compared to a Z-400, Raptor, and Predator 344564[/snapback] I am pretty sure that a banshee will STOMP them, but just to make sure, here is how you find out.... 1. Get them to line up next to you for a drag race. 2. Pin the throttle and shift gears. 3. At end of track shut the bike off, take off helmet. (By the time you get it off, the other bikes should just about catching up to you.) 4. Lean over and ask them what they think about your bike. Here is what you will find out..... they probably got a bad start, or maybe missed a shift, blah blah blah, offer them a rematch. If the rematch is accepted, repeat steps 1-4 until you have thoroughly proved to them that a banshee will hand their four-strokin' asses a whoopin' any time they want. Quote
'SheeRider07 Posted March 24, 2005 Author Report Posted March 24, 2005 How would I check the compression? I don't have the tool to do that. How much does that tool even cost? It will be handy to have once I get a Banshee. Also, how would I be able to tell if the jetting is right? Just look at the plugs I guess? Quote
banshdog Posted March 24, 2005 Report Posted March 24, 2005 How would I check the compression? I don't have the tool to do that. How much does that tool even cost? It will be handy to have once I get a Banshee. Also, how would I be able to tell if the jetting is right? Just look at the plugs I guess? 344635[/snapback] A compression tester and some plug chops. The answers which you seek lie within the confines of the BansheeHQ, all that and more await you.................................... just playin around man. Members on here know banshees inside and out. anything you would ever need is all here. Quote
'SheeRider07 Posted March 24, 2005 Author Report Posted March 24, 2005 Where would I find a compression tester at though? I looked on several sites already and found nothing. Quote
y2kbanshee9187 Posted March 24, 2005 Report Posted March 24, 2005 I can gurantee you wont be upset you got a banshee. As they said, take care of it and it will take care of you. If you ever have any problems, the guys will fix you up here on the HQ. Have you rode one yet? If not, then try to find one to ride. Keep us posted. Quote
PUSH THE THROTTLE Posted March 24, 2005 Report Posted March 24, 2005 Where would I find a compression tester at though? I looked on several sites already and found nothing. 344648[/snapback] Compression testers can be found at a local auto parts store, Sears, or even at a Walmart. I recommend getting a decent one though so you can actually trust it, so Walmart is not the best choice just a last resort. Quote
ellison445 Posted March 24, 2005 Report Posted March 24, 2005 Try pepboys, Auto zone or and car parts store! Compression testers can be found at a local auto parts store, Sears, or even at a Walmart. I recommend getting a decent one though so you can actually trust it, so Walmart is not the best choice just a last resort. 344679[/snapback] Quote
Banshee~ Posted March 24, 2005 Report Posted March 24, 2005 Yea the banshee does good in trails, hillclimbing....its ok on jumping, it takes hours of pratice to wheelie the banshee for along ways.Ive had mine for over a year and I can wheelie for about 30ft only Quote
madkaw Posted March 24, 2005 Report Posted March 24, 2005 Buy the banshee its the most fun to ride. Quote
98bonerSTOCKshee Posted March 24, 2005 Report Posted March 24, 2005 buy one you won't regret it... I play in the mud, water ,sand, ice, snow, hills, jumps and whatever else winds up in front of me..You learn the technique required to operate through the nasty stuff as the time comes. I have learn not to follow the muddy ruts left behind by the monster Utilities I criss cross the rut pulling wheelis and I make it throough.. They don't have reverse, but you really don't need it, my shee can turn a U- turn on any trail that is wide enough for the wheels to fit on.... JUST BUY IT!!! or go with something else... Quote
'SheeRider07 Posted March 25, 2005 Author Report Posted March 25, 2005 Well, as far as riding one, I'm going to go find on that is for sale locally and ride it and see how I like it. I am pretty sure I will like it though. I had 2 stroke twin cylinders snowmobiles before and loved them. Quote
bansheeryder_69 Posted March 25, 2005 Report Posted March 25, 2005 Banshee $3,500 Mods $1,000 Fee to enter local riding area $25 Smoking all your friends over and over again..............Priceless Go with the banshee Quote
97banshee350 Posted March 25, 2005 Report Posted March 25, 2005 well its probly hard for you to get the right answer cuz ure in a banshee forum lol but ya there nice i love mine i love the power, everythin about it, but dont buy one if ure not sure its a lot of money to spend on a machine if its not what u like. Quote
