03350banshee Posted March 22, 2005 Report Posted March 22, 2005 ok I am trying to get my gear shifter off. In order to do that you have to take the foot peg off. but there are two bolts that hold it to the frame. I can not get then off. i tried for a half an hour. i had two other people try to. They will not budge. i soaked them in PB blaster. and still will not move. These are supposed to come off right?? anyone else have this much trouble. Quote
PUSH THE THROTTLE Posted March 23, 2005 Report Posted March 23, 2005 Yep, they are supposed to come out. Unless somebody tac welded them in place or something. Nut up and bust them loose. Can you get an impact on them? Quote
PUSH THE THROTTLE Posted March 23, 2005 Report Posted March 23, 2005 You mods sure make it difficult to post when the posts keep moving, gave me an error Quote
03350banshee Posted March 23, 2005 Author Report Posted March 23, 2005 Yep, they are supposed to come out. Unless somebody tac welded them in place or something. Nut up and bust them loose. Can you get an impact on them? 343498[/snapback] Oh i put so much force behind it that i think i busted a nut. lol i thought of a impact gun but cant get in there. Quote
~~Banshee~~ Posted March 23, 2005 Report Posted March 23, 2005 (edited) Same shit happen to me today....Tried for about an hour.... Edited March 23, 2005 by ~~Banshee~~ Quote
ssanddemon Posted March 23, 2005 Report Posted March 23, 2005 Tried the 'mexican impact wrench' yet? Use a big-ass hammer on the other end of a box end wrench. Works just like an impact. Tip the sucker on end to really get in there without having to stand on your head. Just make sure the wrench is a tight fitting 14mm or you will mess up the hex and be kinda screwed. Or you can heat things up with a torch to expand the area, thus alleviating some pressure- it'll burn the paint tho, so BEWARE. Quote
racer Posted March 23, 2005 Report Posted March 23, 2005 Tried the 'mexican impact wrench' yet? Use a big-ass hammer on the other end of a box end wrench. Works just like an impact. 343548[/snapback] those work better than an impact. with a hammer wrench (the proper term) and a sledge, i can lay down more torque than any 1" impact out there. but id steer away from it here. id say stick with a ratchet and a 14mm shallow socket. then use about a 4 foot section of cheater pipe. Quote
03350banshee Posted March 23, 2005 Author Report Posted March 23, 2005 i think i am going to heat it a little and use a wench and pipe. I am just worried that the wench is gunna slip and round off the bolt. Quote
racer Posted March 23, 2005 Report Posted March 23, 2005 I am just worried that the wench is gunna slip and round off the bolt. 343627[/snapback] thats why you need constant pressure instead of a redneck impact. just make sure your not using a chinese wrench ( ). Quote
MILO Posted March 23, 2005 Report Posted March 23, 2005 (edited) leverage is the key. get yourself a big ass breaker bar with the regular 6 point socket, not a pos 12 point, and a pipe. i usually use the handle from my floor jack. it works great for things like this. Edited March 23, 2005 by MILO Quote
racer Posted March 23, 2005 Report Posted March 23, 2005 leverage is the key. get yourself a big ass breaker bar with the regular 6 point socket, not a pos 12 point, and a pipe. 343653[/snapback] its a proven fact that a good 6 point socket has no more gripping force than a similarly made 12 point. in fact i prefer 12 point sockets. Quote
PUSH THE THROTTLE Posted March 23, 2005 Report Posted March 23, 2005 its a proven fact that a good 6 point socket has no more gripping force than a similarly made 12 point. in fact i prefer 12 point sockets. 343673[/snapback] I prefer to use impact sockets on everything Be careful if you use the hammer wrench if you snap the bolts off you'll be kicking yourself even more. Quote
fixitrod Posted March 23, 2005 Report Posted March 23, 2005 its a proven fact that a good 6 point socket has no more gripping force than a similarly made 12 point. in fact i prefer 12 point sockets. 343673[/snapback] I'd like to see that test. If the top of the bolts not perfect there is more metal to grip the bolt with a 6 point than a 12 point. There's just more room for error with a 6 point. I also do not like 12 point sockets ... if you can't tell. Quote
racer Posted March 24, 2005 Report Posted March 24, 2005 I'd like to see that test. If the top of the bolts not perfect there is more metal to grip the bolt with a 6 point than a 12 point. There's just more room for error with a 6 point. I also do not like 12 point sockets ... if you can't tell. 343973[/snapback] maybe i bluffed a little bit............... but what do you all have against twelve point sockets? Quote
