1800bigk Posted March 16, 2005 Report Posted March 16, 2005 That's a valid point. I want to read the review so make sure you post it. The best way to eliminate spin that I've found is to use a big front sprocket. What kind of gearing are you running 1800bigK? 339755[/snapback] 15/40 with 20" kenda klaws Quote
Fasttoy Posted March 16, 2005 Report Posted March 16, 2005 On your 80 over bore cyls,,you can still go to 90 then a 100 over ...then you sleeve them if you like them..I would go 34 carbs they will work good..if your piped Quote
