joshv5.0 Posted March 11, 2005 Report Posted March 11, 2005 hey my list of mods are in my sig. are there any i'm missing? is there anything else i can do in the to the motor, w/o swaitching to alky, running race gas or rebuilding the entire engine..... again? Quote
rocketboy Posted March 11, 2005 Report Posted March 11, 2005 (edited) yes i see something ! you currently run boyseen rad valves ,ebay those bastards and make the switch to vforce2 or better yet the delta3's ,i have done this switch myself and theres a big noticable difference that your missing out on ,especially in your bottom end rpm,rad valves dont work very good from my experiance with different intakes .also you should lighten your flywheel if you have not already done so.its a very good mod that everyone who trys it loves it Edited March 11, 2005 by rocketboy Quote
ssanddemon Posted March 11, 2005 Report Posted March 11, 2005 Mixing in some race gas (like 1/2 and 1/2) will give a very noticeable gain. I case matched the cylinders when I had the crank out for welding, and it helped the top end power. Gearing down will help a lot, depending on your terrain. I went down a tooth in the front to 13, and it closed the gear spacing up across the board. Quote
Blue Duece Posted March 11, 2005 Report Posted March 11, 2005 (edited) maybe a fatter port Edited March 11, 2005 by Blue Duece Quote
