shady mcnugent Posted March 10, 2005 Report Posted March 10, 2005 I need a complete stock clutch assembly, preferrably used (but not thrashed), for a 1998 Banshee. The condition of the friction plates is irrelevant as mine are still good and I really only need the hub and the boss. Quote
brock_fuzzy_69 Posted March 11, 2005 Report Posted March 11, 2005 which piece do you consider the boss? is that the basket that all the plates go in or the outer part that the springs push on? Quote
broke Posted March 11, 2005 Report Posted March 11, 2005 I need a complete stock clutch assembly, preferrably used (but not thrashed), for a 1998 Banshee. The condition of the friction plates is irrelevant as mine are still good and I really only need the hub and the boss. 337045[/snapback] I've got one on Eaby right now. clutch Quote
fastbanshee4u Posted March 11, 2005 Report Posted March 11, 2005 I need a complete stock clutch assembly, preferrably used (but not thrashed), for a 1998 Banshee. The condition of the friction plates is irrelevant as mine are still good and I really only need the hub and the boss. 337045[/snapback] I got both at yamaha shop for 50.00 Quote
shady mcnugent Posted March 12, 2005 Author Report Posted March 12, 2005 which piece do you consider the boss?is that the basket that all the plates go in or the outer part that the springs push on? 337202[/snapback] The one that the pressure plate bolts to; The piece thtat sits in the basket. Quote
