OK heres the deal i am getting a 4mm stroker crank for my banshee. I have pc pipes and looking to get some v force reeds and K&N filter, it is ported and bore out bout .60 when i do it again! stock crabs other mods are basically looks oh yeah the head is plained?? i know i will have to rejet but will i need a noss head or have to buy bigger carbs i know the bigger carbs would definatly complimant my mods but are they necessary? O r do you know of any problems i may run into buy doing this? How reliable is it going to be? Any info will help! :confused:
Oh yeah i am strongley considering a 4degree timing advance any suggestion with that one aswel i could use the information!
Thanx Jay
Edited by BANSHEE_JAY
                                        Thanx    Jay
335091[/snapback]
you have three choices run a spacer plate, have stock head milled for stroker$100 ,or buy cool head with cut domes $300 to acomodate the stroker.Then the set up will change your porting,depends which way you go. I would say stay away from spacer plate.definetly advnce the timing for more top end power.stock carbs work better than most people give credit for,but you will need big jets. Like 400 - 460. If jetted right it will last you a long time.what is you current porting for?
335101[/snapback]
i beleive its top end i'm not reall sure gonna get the builder of the crank to make sure its ok!! i am no pro at this i'm just a learner! :whoa: I'm trying though
thats a big jet i have a 4mm stroker domes milled out and right now i have a 380 main.  but i guess it depends on the elevation
335960[/snapback]
and temp, and filter setup, and your ports.
