I am currently running 15-41 gearing, at olds, and it just won't pull 4th gear, can't start in second...but the sand was kinda' wet last time out...going for Easter, should I go to 14-41, or leave it alone? will the sand be dry enough? MY mods are as follows:
t-5s , shaved head, 7 degrees advance timing, lightened flywheel, K&N clamp on filters,
jetting is 27.5 pilot, stock needle position, and 280 mains...runs good, but need a little more bottom end.
334313[/snapback]
I'd def. try dropping a tooth. What tires are you running?
I would say drop a tooth on front, I go out there every couple of years and have 14/42 and pull the steep side in 5th easy with 10 paddle extremes.
Sounds lean on the mains, with K&N pods and timing advance I'd say go to 320's minimum. I would try 14 tooth in front so it will pull 4th.
Stock is 14-41. When I was running stock I couldn't hit 4th gear up test hill. I geared down in the front to a 13 and now I can hit 4th like nothing! It's a lot nicer overall riding in sand. :headbang:
I should also mention I am about 215 lbs. with gear on....maybe go to a 12 tooth front sprocket and 380 main jets???
J/K I will try 300 mains, with the current gearing and maybe drop to a 14 front sprocket, half way through the weekend, get a feel for what's better....thanks
as long as your motors stock id run a 13
336045[/snapback]
I'd put the 13 on the front for sure! Thats what I run, I can climb most the hills at the dunes in 4th for the most part, and downshifting to 3rd.
