hi all, I need your opions on what pipes i should get. i ride in the desert some trail some drag. And im go to the dunes about once or twice a month. i was looking at CPI's and T-5's but dident know someone told me T-5's would be a waste for what i do. thanks for all the advice in advance. this forum is the best for banshee info.
id say its a tossup between t5 and rockets ,from my dynobut2000 seat of pants dynometer these 2 are the best in the business. t5s for agressive trails and rockets for open fast riding and drags. :bolt:
sounds like t5s are your best bet. if you do more dragging id go with rockets...
334153[/snapback]
Werd' T-5's are good pipes. The Rockets or CPI's are going to give you more top end though.
334219[/snapback]
I have not had my RDZ pipes for very long,but they seem to be working out good so far.Their a race pipe and,probably not what you need.Got alcohol right after I got the pipes,and I hope to have the jetting dead on soon.Had T-5's before these,they worked great for an all around pipe:good mid range and top end.DO NOT buy the T-6's.I hated them!They had no top end.Had to drop a tooth on the front sprocket to try to get them to pull top on top end.Traded them for T-5's.I don't think you can go wrong with the T-5's. :dance:
I run Rockets in tech trails fine. They perform better than the T-5's I used to have. I can come to almost a dead stop in a turn and pull out just as fast if not as fast as one of the other shees we run with that has the FMF SST.
All in your gearing and motor setup.
I run 18" rear holeshots and a 15tooth front sprocket. 16 tooth front on more open trails and tracks. I'm heading out here in an hour to run in some tight trails again with the rockets. Keeping up with a vforce 700. And they have auto trannys
