simonsays Posted March 5, 2005 Report Posted March 5, 2005 Few weeks ago i bought a 2003 banshee black and yellow.. i had it fitted with trinity stage Iv pipe kit, and racing filters. i am worried about jetting because i dont know what it is and i am scared i could fuck up my bike if i dont adjust it properly. i found that when i going in 6 th gear the power has a bit of a lag at the beging... is this normal? Quote
SHEEBANSAVAGE Posted March 5, 2005 Report Posted March 5, 2005 What are you running for jets right now?? Stock or have you changed them out? Also what is the altitude you ride in mostly? Quote
fastbanshee4u Posted March 6, 2005 Report Posted March 6, 2005 Few weeks ago i bought a 2003 banshee black and yellow.. i had it fitted with trinity stage Iv pipe kit, and racing filters.i am worried about jetting because i dont know what it is and i am scared i could fuck up my bike if i dont adjust it properly. i found that when i going in 6 th gear the power has a bit of a lag at the beging... is this normal? 333869[/snapback] call Trinity Quote
simonsays Posted March 6, 2005 Author Report Posted March 6, 2005 i am using the stock jets..... the thing is i have power in gear 6 when it reaches a certain rpm.. at low rpm when i press the throtle full it cuts off a bit before it starts accelerating Quote
rocketboy Posted March 6, 2005 Report Posted March 6, 2005 i am using the stock jets..... its probably running very lean on the main !!! caution on riding it like that ,better get some bigger mains or kablammy Quote
race-a-holic Posted March 6, 2005 Report Posted March 6, 2005 i am using the stock jets..... its probably running very lean on the main !!! caution on riding it like that ,better get some bigger mains or kablammy 334199[/snapback] Better listen to Rocketboy.Depending on where your at,I'd at least put 280 jets in it.May have to go larger.That ought to keep you from burning it up. Quote
05bansh Posted March 6, 2005 Report Posted March 6, 2005 Re-jet it properly or your engine is going to be toast man! Quote
race-a-holic Posted March 6, 2005 Report Posted March 6, 2005 Better listen to Rocketboy.Depending on where your at,I'd at least put 280 jets in it.May have to go larger.That ought to keep you from burning it up. 334230[/snapback] Better listen to Rocketboy.I'd at least put 280 jets in it.That should keep you from burning it up.Calling Trinity would be a good idea. Quote
simonsays Posted March 7, 2005 Author Report Posted March 7, 2005 Better listen to Rocketboy.I'd at least put 280 jets in it.That should keep you from burning it up.Calling Trinity would be a good idea. 334234[/snapback] do i buy need jets or can i adjust them and if how? sorry i know i must sound real stupid but this is my first banshee Quote
01bansheeke Posted March 7, 2005 Report Posted March 7, 2005 yes, you need to buy new jets. I'd say get 280-320's. with no porting you should be right in there. Start fat and work your way back down. Quote
simonsays Posted March 7, 2005 Author Report Posted March 7, 2005 sorry guys for all this hassel. but i found out when it had the fillters installed it was a full kit with the jets and mods. Quote
bigboybanshee Posted March 7, 2005 Report Posted March 7, 2005 If it is not your jetting then try changing your gear ratio. Maybe you could drop the front sprocket one size to a 13, assuming you're running stock gears. Quote
