Hey
Removed the mufflers from my bike. Just hacksawed them off. Standard expansion chambers....
And removing the airbox lid....
What jetting will I need???
Im at sea level and the average temp is around 30 degrees celcius.
What other info do u guys need to help me get the jetting right/??
I want to see what your plugs look like after you riding without your silencers on.... :whoa:
Seriously though man, just buy you a set of aftermarket pipes and ditch the stock expansion chambers...I honestly think you're doing more damage than good by running it that way, and you'll get a similar effect if you would just get some pipes that were designed to flow better rather than butchering the stock ones. :shrugani:
Getting rid of the silencers off your stock pipes won't do sh*t. The silencers don't provide much, if any, back pressure. The power is made in your pipes/expansion chambers, so unless you change them, your just pissing in the wind. All your going to accomplish by removing the silencers is making it sound like crap.
Get some real pipes and leave the ones you have alone. You can remove the airbox lid for a little bit of help.
Later.
Hey
333293[/snapback]
I HOPE YOUR JOKING!!!! :blink:z3.gif
Your kind of in the experimental range hacking off your silencers as far as jetting. It wouldn't hurt to go up a couple sizes, go up about 3 sizes if you remove the air box lid.
Dont remove the airbox lid while using the stock filter, the airbox lid holds the filter in place. Some people have screwed it to the front of the airbox so they could run lid off with the stock filter. I would recommend running an aftermarket filter and adapter plate in the stock airbox to run with the lid off.
Hey
333293[/snapback]
good lord :huh::whoa: thats a strange case of tinkeritis youve got there. stock she pipes are more usefull as boat anchors than 2 stroke expansion chambers. :lol: youve likely lost performance and your motor will not respond well to this mod (if thats what you call it)
get on ebay buy a set of used fmf fattys or pro circuits for cheap 200$.youll gain performance and
youll be able to get some accurate jetting numbers your looking for and the added benefit of your bike not looking gay as hell with cut up stock pipes :blink:
haha my current mufflers are gutted, all the baffle has fallen out, spark arrestor is gone...
I have K & N filter so what jets would i go to to run no lid??...anyone got any good 2nd hand pipes??? postage to australia will kill me ;(
