CowboyBanshee Posted February 28, 2005 Report Posted February 28, 2005 Has anyone done an A-arm conversion...my 87 with J-arms is a excellent runner, and I would like to update it a bit...but I cant seem to find anything more than word of mouth about it... Quote
SuperChris Posted February 28, 2005 Report Posted February 28, 2005 Do you bend your J arms? I only did the conversion because I kept bending J arms. If you do it, it's gonna add some weight, cost a bunch of money, and handle the same. If you do, be sure to make a bunch of gussets and weld them on good. Mine came apart and ruined a new set of shocks. Quote
PUSH THE THROTTLE Posted February 28, 2005 Report Posted February 28, 2005 My recommended conversion $550 from the local stealer. Elka Quote
SuperChris Posted February 28, 2005 Report Posted February 28, 2005 That would have been cheaper for me in the long run after replacing all the A arms and shocks I bent before figuring out I needed so many gussets. Quote
PUSH THE THROTTLE Posted February 28, 2005 Report Posted February 28, 2005 That would have been cheaper for me in the long run after replacing all the A arms and shocks I bent before figuring out I needed so many gussets. 331212[/snapback] I didn't trust my welding or any body elses to the torture that I want to put that frame through, plus you can make something off the old frame when you sell it. Quote
