I had a little more port work done and that seemed to shine a light on a problem with a weak spark. The problem was on top. Kind of a sputter or bog. I closed up the gaps to .018 and its runs great. My builder told me essentially that because of the mods the spark is being blown out because it is not strong enough. I Also was told that its not uncommon.That even a brand new banshee ignition (CDI) could have the same effect. Has anyone had a similar experience and does any one have any info on other ignition options that worked out good for them?
Sounds like your compression has been bump way up. Really high compression will cause the spark to be blown out. A good aftermarket or TZ ignition should help with this problem.
