I need some help jetting my banshee. I'm going to be riding at glamis mainly which is pretty much sea level. Temperature is around 50'-60'.
Main jet?
THANKS IN ADVANCE!
My Mods:
-Rocket Pipes(In Frame)
-Keihin 28mm PWK's
-K&N Pod Filter(Clamp On)
-everything else is stock!
Edited by wingerdingershee
  • 4 weeks later...
Main jet?
THANKS IN ADVANCE!
My Mods:
-Keihin 28mm PWK's
323058[/snapback]
Did you figure out what jetting you need to run because I'm having the same jetting issue I have Rocket Pipe, 30mm keihn carb, and everything else is stock
i have 28/30mm pwk kehins with rockets vforce k&n and a list of other goodies .im @+1300 elevation
155 mains/ 55 pilots/ needle in middle or down one more notch/ air screw out 1 turn
should put you damn close to where you should be at IMO :bolt::cheers:
its gonna pull like a mofo too!
Edited by rocketboy
