zilladude Posted February 14, 2005 Report Posted February 14, 2005 Only 3 gallons of fuel ran through it, has too much power for the riding that I do. Cylinders are .020 over, crank is a long rod +4mil wiseco, 795 series pistons & spacer plate. I also have the Boss intake & 33mm PWK carbs w/braided cable. I have over 1700 into this not including the cylinders. Make me an offer. Quote
locogato11283 Posted February 14, 2005 Report Posted February 14, 2005 Only 3 gallons of fuel ran through it, has too much power for the riding that I do. Cylinders are .020 over, crank is a long rod +4mil wiseco, 795 series pistons & spacer plate. I also have the Boss intake & 33mm PWK carbs w/braided cable. I have over 1700 into this not including the cylinders. Make me an offer. 322963[/snapback] what kinda riding do you do that you need less power?? Quote
zilladude Posted February 14, 2005 Author Report Posted February 14, 2005 It is a little bit of a handful when whipping through the trees where I ride. I am going to go back to a stock stroke & a single carb like I had on my other Shee. Quote
1800bigk Posted February 14, 2005 Report Posted February 14, 2005 (edited) hmm, would you seperate any thing, if so how much for the crank and carbs Edited February 14, 2005 by 1800bigk Quote
zilladude Posted February 14, 2005 Author Report Posted February 14, 2005 I may have a buyer for the pakage, if not I will piece it out. Quote
bansheeracer18 Posted February 14, 2005 Report Posted February 14, 2005 ill trade u a set of jugs bored .80 over with pistions and a stock trued and welded crank for and my trinty 2-1 with 35mm carb for your set up Quote
. Posted February 14, 2005 Report Posted February 14, 2005 Hell....I'd trade you my polished cylinders, never ran passion ported mx type style port cylinders with pistons, my stock crank still within specs, and buy you a carb setup..... Quote
zilladude Posted February 15, 2005 Author Report Posted February 15, 2005 Everything is sold pending payment. Quote
