lineybiker_11 Posted February 11, 2005 Report Share Posted February 11, 2005 hey i got a mild port job and the head milled with stock pipes and after i jetted it all in i have 250 mains raise needle one slot and 20 pilots with the airscrews at 1 1/2 turns. and it ran and idled awsome the first day i got the carbs on and cleaned and stuff but now when it sits and idles it loads up and fouls the plugs but will run good at mid to wot. so i don't know whats wrong i've cleaned the carb 3 or 4 times thinking it was that but it wasn't i just don't know how it could change that much overnight. can you please give me some suggestions Quote Link to comment Share on other sites More sharing options...
1800bigk Posted February 11, 2005 Report Share Posted February 11, 2005 pilot might be too small, try 25 Quote Link to comment Share on other sites More sharing options...
Banchetta Posted February 11, 2005 Report Share Posted February 11, 2005 Are you sure they are 20 pilots? Stock carbs? Have you checked your reeds? Equalizer tube in place between the two carbs (1/4"x2"long), make sure the slides are in the right carbs, (cutaway facing the air box) Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted February 13, 2005 Report Share Posted February 13, 2005 check your float height also, if it's to high it will load up at idle... Quote Link to comment Share on other sites More sharing options...
