:confused: WELL I HAVE 2 GRAND TO SPEND ON MY BIKE AND CURRENTLY ITS JUST NOT FAST ENOUGH CUZ I'VE BEEN BEATIN BY A JETTED AND PIPED 450YZF GOING UP A DUNE IN GLAMIS.
CURRENT MOTOR MODS
PRO CIRCUIT PIPES
KN FILTER
BORED 60 OVER
JETTED 220 STOCK MAIN
NEEDLE CLIP STOCK
PORTED INTAKE/EX JUGS- DONE BY ME...
IF ANYONE HAS A TEMPLET FOR A PORT JOB I WOULD LIKE IT
STOCK GEARING
STOCK DOMES/HEAD
:yank:
SO WHATCHA GUYS THINK? I NEED SOME POWER!!!!!! :bolt: I WANT TO DO SOME MX ON IT ALSO.
  • Replies 41
  • Created
  • Last Reply
Top Posters In This Topic
hmmmm...you need to figure out what you are going to do before anyone makes too many suggestions i would imagine. Running up hills at glamis....and then turning around and doing mx are two different animals. non-purpose built bikes are tough to build. I'd say ditch the pipes(sell em) ditch the carbs, go get a port job, get some cpi's or rockets, then get some good carbs. SHould be right around your 2g limit. But you'll be haulin ass :D
oh yeah, ditch the stock head or have it milled. You can usually find used cool head at reasonable price on here or ebay.
Edited by 01bansheeke
i live in texas now but i make a run out to glamis maybe once a year, sucks cuz i used to live in cali, but near dfw texas is oklahoma and the have some sand dunes that dont really compare to glamis or even pismo for that matter. in all seriousness i want to make this shee very very responsiVe to the throttle and just rip through the sand. as for the mx, only places to ride around here are mx tracks so to get away from my girlfriEnd some weekends i ride at tracks... im guessin simple regearing will allow me to blip the throttle before a jump so i clear no prob... but the ultimate question is: FOR 2 G'S WHAT CAN I GET TO OPEN UP MY SHEE SO THIS DAMN YFZ 4FIDDY WILL GO AWAY!!!! :cry:
Edited by NEVER SATISFIED
OK I CAME UP WITH A SETUP PACKAGE... LET ME KNOW? :confused:
CPI PIPES
CPI BILLET HEAD @ 17CC
RAD VALVE W/ CRABON FIBER REEDS
BOOST BOTTLE
TRINITY STAGE IV 35MM CARBS WITH INTAKE MANS
AND A GOOD PORT JOB.. ANYONE HAVE A TEMPLET FOR THIS TO DO MYSELF?
:headbang:
Boost bottle is a waist of money!!
CPI PIPES
BOOST BOTTLE
:headbang:
319515[/snapback]
The smaller the number on the domes means the more compression you would get when installing them. Example: 21cc domes might give you 150psi compression, as where 20cc domes might give you 170 psi compression, and so on depending on your elevation. If you go to 17cc domes, you will HAVE to run high octane race gas or risk detonation. If you buy a NOSS head from dlnoss, I'm sure he'll be glad to help you figure out which dome size is best for you :cheers:
Hot Duner port, bore job and forged pistons, Noss head, 33mm carbs with billet intake, v-force reeds, and a set of Sheerer inframes for about $1900.00...goodbye 450!
319595[/snapback]
TULSA... HRMMM HOW FAR IS THAT FROM DFW... I KNOW I'LL HAVE TO DRIVE THIS MOTOR UP TO YOU!!! THAT PRETTY MUCH A HAUL IN MY MOTOR AND HAUL IT OUT WITH EVERYTHING DONE... ?
run a stroker setup with a woods type port (should get you plenty of power for the yfz), get some cpi's or other top end type pipe, and then switch out with a set of LRD's or comparable pipe for when you ride mx.
