PLEASE HELP
ME
MY BANSHEE WAS DYNOED BEFORE WITH dmc alien AND A BOOST BOOTLE + K & N AIRFILTERS REACHED 41 HORSES WITH JETTING
ITS SLOW COMPARED TO OTHERS WHO HAVE THE SAM MODS THAT I HAVE
THEN I ADDED PISTONS + REEDS AND REED SPACERS = vitos super stock pistons gearing 15/40
HEAD + 22CC DOMES + AFTERMARKET RADIATOR AND DIDNT RE JET?
SO A BANSHEE WITH PROCIRCUITS AND V FORCE DELTA REEDS CAN CATCH UP WITH ME :cry:
What should i do ?
i want my banshee to go faster :bolt o
the temprerure in kuwait i can reach to high 50 low 40 degrees C celcius
im running 290 mains
shoudl i change my jetting
You do have something wrong. A stock banshee should be around 39 or 40 HP. When you put pipes and a K&N filter on you should gain about 7 to 10 depending on the pipes.
Your gearing is way high. Is top end speed what you want?
22cc domes are just a little up from stock. You should go to 20cc domes and mix 92 oct with trick110. Then advance the timing by 4 degrees. Look at the spark plugs. If they are brown your good, if light brown to white you need more jet. Try going to a 310. good luck
landscape rises to a maximum elevation of 306 meters (1,004 feet)
and the weasther in the summer is110- 120 degrees(F) FARANHEIT
SHOULD I REMOVE MY DEGREEY KEY AND GET AN ADVANCED TIMING PLATE
BEECUASE IN THE DEGREEE KEY I ONLY CAN PUT IT IN +3
Don't worry about the dyno chart, that is just to compare mods, you can't compare numbers to others. I do my dynoing on a car dyno, I have 8 straps holding my quad in place w/ my shocks x'd out and tires half sqatted...so my numbers will be a lot lower then someone w/ an actual atv dyno...but anyways, what are you running for an air box setup? Filter? compression?? Do a wide open run in 6th gear for 5-10 seconds, shut it down, coast to a stop, pull the plugs, either take a pic of them or change them and bring the plugs home to get a pic of them and post them on here. We can tell where you at for the main jets...now you have some homework to do...
318605[/snapback]
What he said....
