scotts96fast Posted February 4, 2005 Report Posted February 4, 2005 port and polish......When polishing do you guys polish everything?...intakes,transfer and boost ports....My intakes and exhaust ports and pretty good.Just wondering if there will be a difference with the transfers and boost ports polished. Quote
Leadfoot350 Posted February 4, 2005 Report Posted February 4, 2005 use about 80 grit on the intake and transfers and just match up the sleeve to the cylinder. Polish the exhaust as shiny as you can get it. Quote
mat Posted February 4, 2005 Report Posted February 4, 2005 The general theory is that you should only polish the exhaust ports. Any of the ports that the fuel/air mixture travels through should be slightly rough. This is so that the air is turbulent and keeps the fuel in suspension. Quote
RNBRAD Posted February 4, 2005 Report Posted February 4, 2005 The general theory is that you should only polish the exhaust ports. Any of the ports that the fuel/air mixture travels through should be slightly rough. This is so that the air is turbulent and keeps the fuel in suspension. 317573[/snapback] Word Quote
SANDSTAR Posted February 5, 2005 Report Posted February 5, 2005 Don't polish the intakes. Go over them with a dremmel carbide cutter bit. It will give you the perfect finish in order to properly atomize the fuel into the air. If you got them off, get a sportport template and port those babys! Just be sure you got strong shoulders, cause it'll rip your arms out of their sockets after a good sportport! Quote
