hey guys
well my banshee runs great but there is a problem in it and i still didnt figure it out so i need your help please.
well here is the problem my banshee runs great but when i try to pull a wheelie in 1st or 2nd or any gear teh motor opens and then just bogs down to normal and also when im on trails the motor takes time to open the full power its wasnt like this before i tried cleaning the carbs but still same shiat
You may have put the float level too low, And are starving the thing. It sounds like you might be talking about clutch slippage also if when you hammer on it, the motor revs up, then slowly starts to bog.
You need to keep giving it gas when wheelying :D
316176[/snapback]
lol ya i am a wheelie pro if u didnt know i dont know but in old blaster hq forums i had alot of team kyoshi videos
any way ya the the front end just jumpes and even if i gased it to hell it still bogs low
316360[/snapback]
Yea dude u might not be getting enough gas to the motor
I cleaned the carbs on my old Craptor once and accidentally bumped the floats and it acted like that. I would definately check your float levels. When you hold it upside down, the floats should be parallel with the base of the carb I think but double check that.
