i lightened mine to same diameter specs most guys use here but i also added 6 bored holes in its face and some other little removal tricks ,itsa very very light ,revs like a damn 80cc dirtbike (rightnow ) the lighter the better ,youll love this mod its all gain!! :clap:
314564[/snapback]
Where would I want to take mine to have it lightened up? Can any machine shop handle it, or should I only go to a bike shop?
314736[/snapback]
PM BDBanshee on these forums, i know he does them for ya B) and i think boonman does them also
stu
wish I knew exactly how to do it or I'd post some pics and how too's. this way everybody learns from this site. Dont worry guys I'm sure somebody will post some tricks.
Edited by 1sreamin350
315174[/snapback]
There are some pics on the site. I don't know where. I posted some up some time ago I do remember. The only problem with people doing them themselves, is things can get dangerous real quick. You need to have an arbor, specifically made to hold a banshee flywheel. And the only people capable of doing this should be accomplished machinists. It's not like drilling a hole. If you take material from the wrong spot, and the flywheel comes apart, you may trash the stator. or other things. Basically, you put it on the arbor, chuck the arbor in a lathe. And turn it down. De-bur it, and your ready to go. Anyone with the proper knowledge can do it. It's just that it should be done right. Or you risk an out of balance flywheel, and problems down the road if done incorrectly. :cheers:
315296[/snapback]
Does'nt fet any better than that! Thanks for helpen out boonman. :huh:
315296[/snapback]
Might I also add that if not machined concentric with the crank, you can and probably will trash the crankshaft. Anyone that understands how to machine the flywheel exactly true to the crank shouldn't have too many problems, but just getting it close isn't good enough. Not trying to discourage you, just making sure you know it has to be right.
