2stroke_addict Posted January 19, 2005 Report Posted January 19, 2005 (edited) i don't see toomey's 6 pipes mentioned a lot, instead FMF, rockets or other brand are mentioned even recommended. What is wrong with these pipes?? they work good for me, or maybe you people out there know something i don't. am i on the wrong boat here?? so let's hear it. Edited January 19, 2005 by 2stroke_addict Quote
05bansh Posted January 19, 2005 Report Posted January 19, 2005 They are good pipes if you plan on keeping you engine stock for the most part. The T-5's perform better than the t6s if you are ported. Quote
NMBANSHEE Posted January 20, 2005 Report Posted January 20, 2005 They are good pipes if you plan on keeping you engine stock for the most part. The T-5's perform better than the t6s if you are ported. 309070[/snapback] Same as above and I'll add that a good portion of the people on here eventually will or already have ported their egines, so most people want a pipe that will grow with their mods. Quote
jumpcuts Posted January 20, 2005 Report Posted January 20, 2005 Quote from the guys at Toomey Racing: The TR6 pipe design, is for the stock engine specifically. Anytime you modify the engine where you will be altering the exhaust gas temperature, (Exhaust Port change, or compression ratio change) you will be deviating from the TR6 design capability. The reason it is the best, and works so well on a stock engine, is that it is a VERY specific design meant to maximize the potential of the stock engine, which most people actually have. It is not designed to accommodate any other port design range at all. Our T5 design DOES have this wider design capability, thus it works well on stock OR modified engines, right up into the higher RPM ranges as well. But, not AS well on the lower RPM ranges, at which a stock engine/RPM range operates, as the TR6. So, for low-end and mid range power, in the stock engine/RPM range, the TR6 is your best choice, and for modified engines, or sustained high RPM operation, the T5 is the best choice. Quote
banshee tuner Posted January 20, 2005 Report Posted January 20, 2005 I know some riders that decided to save 100 bucks cause they were told that there was no performance difference. The fatties and pro circuits generally run 100 bucks less than t5's used to and t6's are even more expensive. Quote
