QuadMX Posted January 18, 2005 Report Posted January 18, 2005 All this is off a 96 Banshee just tryin to get rid of it powdercoated orange swingarm/carrier with new pivot bearings with grease zerks in pivot and carrier (used but great shape) stock 26mm carbs with tors and throttle cable (used but still good shape (needs re-sync idle-few strands of cable snapped where mounts in throttle)) front brake lines (used but still good shape and will work) upper a arms (both bent) two stock milled heads ((one black the other paint was stripped off) both messed up-need domes recut or whatever) pair of stock jugs (need resleeving or .120 (possibly more) boring) stock clutch plates and springs (fibers pretty much gone but steels would be decent, good springs yet) two stock front headlights (good shape still work) rear tailight (good shape still works) stock swingarm skid (pretty roughed up but still usable) stock intakes (cracked a bit and makes engine run slightly leaner than what should but i never had too much of a problem with them) 1/16 " front wheel outer insert powdercoated orange (good shape) front inside wheel brake guards (bent from ripping off of machine but still mount) engine stop/run and lights hi lo and off switches (good wires and clip, switches still works) tors button that goes inside the throttle housing (works) probably have the tors box somewhere around too if i really looked for it clutch cable and emergency brake cable (little lube they work fine) tie rods without ends (good shape) front fender mounts that go to frame right in front of the engine (good shape) stock reeds (good shape still useable) stock handlebar key mount (good shape) stock rear brake rotor on hub (hub still good disc slightly bent) 18x11x8 Turf Tamers on ITP Steel wheels (tires and wheels like brand new used only a few times) 22x12x9 Realtors on Aluminum wheels ( tires and wheels like brand new only used a few times) stock front and rear tires (NOT ON RIMS (still a little bit useable maybe for onroad riding not much tread left) 16x8 American Racing Rims with 255x16r17 tires (6 lug pattern off an 89 Silverado (tires will need to be changed but useable if not in extremely wet conditions)) Anybody wants any of this stuff make me an offer and I'll get back to you. I'm up for almost any offer as long as you aint kickin me in the nutz. Thanks Bob Quote
brock_fuzzy_69 Posted January 19, 2005 Report Posted January 19, 2005 22x12x9 Realtors on Aluminum wheels ( tires and wheels like brand new only used a few times) would love ot knwo more about these but i bet shipping woul be at least 30 bucks? Quote
MRMOONEY Posted January 19, 2005 Report Posted January 19, 2005 stock jugs what size are they now and how much u want for them, pm me with info Quote
QuadMX Posted January 20, 2005 Author Report Posted January 20, 2005 I got 2 stock pipes with the middle pipe and heat guards for sale too I would also like to add I get a shipping discount cause of where my mom works so I can normally ship for about 1/3 - 1/2 less the regular shipping cost. Bob Quote
. Posted January 20, 2005 Report Posted January 20, 2005 got any pics of the realtors pics to [email protected] Quote
QuadMX Posted January 21, 2005 Author Report Posted January 21, 2005 got any pics of the realtors pics to [email protected] 309534[/snapback] I think the realtors are sold. But if the guy doesn't want them I'll send you some pics. Quote
QuadMX Posted January 24, 2005 Author Report Posted January 24, 2005 Bumpin it up! 310583[/snapback] Come on guys somebody's gotta need somethin else. Realtors are gone, and everybody that said they wanted somethin never replied again. Help me out a little here Bob Quote
broke Posted January 24, 2005 Report Posted January 24, 2005 I'm up for almost any offer as long as you aint kickin me in the nutz. AHHH, COME ON!!!!! Quote
#51 BANSHEE Posted January 25, 2005 Report Posted January 25, 2005 AHHH, COME ON!!!!! 311492[/snapback] got any pics of the headlights Quote
AtvStunter Posted January 25, 2005 Report Posted January 25, 2005 engine stop/run and lights hi lo and off switches (good wires and clip, switches still works) rear tailight (good shape still works) Need them .. how much shipped to 12470 Quote
QuadMX Posted January 25, 2005 Author Report Posted January 25, 2005 (edited) AHHH, COME ON!!!!! 311492[/snapback] Sorry everybody as some of my PM's have not been going through so please check back in here for replies. MR MOONEY The cylinders are .020 over like I stated above but they will need major boring or resleeving work. Otherwise they are in good shape...studs all there etc. #51 BANSHEE I can get some pics of the headlights in about 5 minutes if you gimme an email address as I don't have the pics hosted anywhere, but they are in good shape except the back cover on one of them doesn't stay in place so there's a zip tie holding it together but isn't noticeable unless you're up close staring at it. AtvStunter I can get you the setup for 40 bux shipped if you are still interested. And I can get you some pics if you'd like. Edited January 25, 2005 by QuadMX Quote
QuadMX Posted January 25, 2005 Author Report Posted January 25, 2005 The tail light and jugs (Intakes and reed cages not included...unless you really want the intakes they are a little cracked, but still worked for me...10 bux more you can have them) Quote
