Not a night and day difference but well worth the $25 for a degree key. You will not notice a difference unless you have aftermarket pipes. The banshee timing advance helps at high rpm's the blaster adds at low rpm's.
Do you have to have an aftermarket timing plate or degree key to adjust the timing? Or can you adjust the factory?
okay I ordered my adjsutable plate from ricky stator, it was $35, for the plate, $15 for a flywheel puller,
and like ten bucks shipping/handling, got it in like two days. 'bout sixty bucks, for all
it has settings up to +10, -10, thinking about + 5 what do you think? and while I have it off it is going out for the "boon-tune"
307443[/snapback]
As sort'a already said (but you asked)..you can have your stator modified, put in someone else's already modified stator (or plate)...OR use a degree key. They both do the same thing. A modified plate is somewhat 'adjustable' for different timing settings. A key is just 'x' degrees.
Offset keys are generally considered not a good idea if you're changing it much. The more advance/retard in a key, the less metal there is holding the flywheel in place.
A key is cheap and less trouble. 'You get what you pay for!' 'eh?
Factory isn't readily adjustable...thus why riders get their oem plates/stator modified.
