Anyone looking to buy a used 7mm stroker crank Im going to be selling mine on Ebay in a few weeks. Just thought I'd give yas a heads-up so you can ponder owning a 7mm stroker Banshee. Its ready to drop in your cases. Case's will need trenched for this crank. Its got 5mm long rods too. The clucth side of the crank uses a TZ bearing that uses roller bearings instead of ball bearings. its a nice crank and its within all tolerances.
Start saving your pennies now, its going on Ebay in a few weeks. I have pictures I'll post. Any questions just ask.
  • 4 weeks later...
Bump. :evil:
Cranks going on Ebay real soon. Save some of your income tax return for this fantabulous crankshaft. I just had Dan Wade from Patriot give it a checkup and it passed all his tests, so she's ready to drop in. yer cases will need trenched for this crank to work for ya. Its a 7mm stroker with da long rods :headbang: . Tz bearing on the clutch side B) .
Bump bump babump
  • 4 weeks later...
Still got the crankshaft. gonna work on getting it listed on Ebay tonight and it should be on Ebay tomorrow\Sunday. It should make one a hellava good motor.
Hey folks, I wanna sweeten the deal here a little. If anyone here is the winning bidder, please contact me at the end of the auction and specifically tell me your a member at BansheeHQ. What I'll do for the BHQ members is... give you 30 days from the end date of the auction to have the crankshaft inspected by the engine builder of your choice. If your guy finds the crank unsuitable to use, I will refund your money. You gotta pay for the return shipping and the crank inspection tho. 30 day warrenty, and im not going to buy back the crank without proof you had it inspected and it failed the tolerance tests. I'm not going to buy back the crank because you decided you "really didnt need it". You'll need to have it inspected and the crankshaft fail specs and tolerance tests for a refund.
Im hoping to lure bidders who are a lil' nervous about buying a used crankshaft.
-denny :)
