thesheekilz Posted December 23, 2004 Report Posted December 23, 2004 will a six inch wide tire fit on a seven inch wide rim; if so, how does it look? Quote
thesheekilz Posted December 23, 2004 Author Report Posted December 23, 2004 i got a set of holeshot mx fronts 19-6-10 and the stock shee's rim is 7 inches wide, thats a half inch on each side. that seems like a pretty big gap. Quote
banshee76179 Posted December 23, 2004 Report Posted December 23, 2004 It will but, its gonna look like crap! Quote
thesheekilz Posted December 24, 2004 Author Report Posted December 24, 2004 does anyone know where i can find some six inch wide front banshee rims? Quote
locogato11283 Posted December 24, 2004 Report Posted December 24, 2004 put them on, itll look fine. Quote
bansheefreak Posted December 24, 2004 Report Posted December 24, 2004 put them on, itll look fine. 297342[/snapback] i agree Quote
banshee76179 Posted December 24, 2004 Report Posted December 24, 2004 Heres a 6in tire on a 7in rim.. when I first got the the rolling chasis.. Quote
Ducman Posted December 24, 2004 Report Posted December 24, 2004 just dont ride it in really rocky areas, the bead of the rim is very vulnerable sticking out like that, also will come off the bead a little easier if the pressure is very low, otherwise its fine. Quote
thesheekilz Posted December 24, 2004 Author Report Posted December 24, 2004 i only ride motocross so i should be okay, thanks guys Quote
sredish Posted December 24, 2004 Report Posted December 24, 2004 I'd run at least 10 pounds in it, but if 76179 is running them that way, then i guess it works.... Quote
