8HONDO Posted December 20, 2004 Report Posted December 20, 2004 anyone running rockets that ran them in the winter? what was your jetting? i am running stock carbs with a mild port and polish. currently running 320 on the main and a 35 pilot for ice. but i am switching to rockets and was wondering what the difference was in jetting? Quote
superchicken Posted December 20, 2004 Report Posted December 20, 2004 (edited) huh,im in kinda in the same boat as you.im getting my jugs back,today and gonna put them on with a bunch of other goodies i got for cristmas.maybe someone can help us both out.mods are 28 mill mikunies k&n clamp ons v-force 2's mx-woods port 21 cc domes dyna ignition sea level 30 degrees outside just need a good starting point Edited December 20, 2004 by superchicken Quote
Ducman Posted December 21, 2004 Report Posted December 21, 2004 It does sound like you both should be pretty close. I would jet the 28mm Mikunis pretty close to what you would jet a stock carb. With a bigger carb the main jet size goes down. I bought a new set of Mikunis TM 34's and had to go 2 sizes smaller on the needle jet orafice, what they came with was way too rich, I don't know what the 28's come with they might be totally different. The main thing I can tell you is that rockets like a bigger main than most any other pipe out there. When I wen't from FMF's to rockets with no other changes on a stock port motor I went from 290's to 320's and it was pretty close, just a slight bit rich. I'd guess 340 or 350 for both of you mabe bigger if its colder than 50 degrees. Quote
Nighty Posted May 11, 2005 Report Posted May 11, 2005 My set of rockets arrived today. I'm going to try them with my current jetting: 25 pilots Toomey needle on 5th clip 360 mains K&N inbox filter with K&N powerlid on the box. I'm @ sea level and currently running t5's. I'll also be replacing my stock reedcages (boyeson dual stage petals) with a vforce-2 set. But 1 thing at a time. pipes first. I have two 30 pilots availeble, but no richer mains. 3 steps richer on the mains would get me near 400 main! are those even made? Quote
locogato11283 Posted May 11, 2005 Report Posted May 11, 2005 My set of rockets arrived today. 3 steps richer on the mains would get me near 400 main! are those even made? 367848[/snapback] i know a guy that ran 450's in his stock carbs. Quote
superchicken Posted May 11, 2005 Report Posted May 11, 2005 well i have tuned my she alot since december when i got my pipes.im running 370's with 27.5 pilots,and middle clip on 28 mill. mikunies.its a tad rich since it has gotten warmer out but it doesnt bog at all,so i left it alone. Quote
Nighty Posted May 11, 2005 Report Posted May 11, 2005 Thanks. I hope to give it a go this weekend, If it doesnt run ok then i'll need to go richer aswell. i'll leave the needle as it is, try the 30 pilots and will look around for 380 mains. Quote
Minkia38 Posted May 13, 2005 Report Posted May 13, 2005 any port work throws a monkey wrench into your plans! but on average, switching from T5s or FMF, you go UP 306 main jet sizes with the rockets. Quote
