ok i got my banshee from my cousin not to long ago and im starting to learn more about it. he put a k&n on it and he said he didnt rejet. wouldnt i be running lean if he didnt? and if he didnt what jets should i change to? oh yeah and i live in the detroit mi area. thanks in advance
it depends do you have pipes on it. is the air box lid removed? if its just the k&n try going about 4 sizes larger on the main it should get you in the right ball park
For just a typical air filter change from stock to K&N should be a couple sizes bigger, maybe 3, but you'll have to find out whats in there and then go up from there. We can't tell you whats in the machine currently. If the snorkle is not removed from the front of the air box, remove it also.
what should the jetting be at on a completely stock bike with the snorkel removed?
295091[/snapback]
Well, it depends on how it was put together from the factory. There is a "stock" spec for the banshee, but it was actually shipped to different areas with different main jets depending on the region it was shipped to. It also depends on your elevation if your asking about a rejet. I'd say around 210 to 220, but it can vary a lot depending on the variables i mentioned.
