Hello again, I want to purchase a adjustable timing plate. Which is a good brand to go with?? Ricky or Trinity or some ones off ebay or does it really matter?
Also, when I install it, is there any other issues I should be worried about?
thx in advance
there all about the same with a diffrent name stamped on them, choose whichever, its not really hard to change, just make sure you have a flywheel puller.
No complaints with my RS adjustable plate, hell the stock wattage stator has held up great compared to the 2 OEM stators I toasted. <_<:confused: But anyway...as far as when installing it & things to worry about; this isn't really anything to worry about, just a head's-up...you'll probably need to do some filing on it to get it to fit in, no biggie though. Here's some pics of when I did mine & you can see where it's binding & where I had to file a bit. :cheers:
Hope that makes sense... :rolleyes::D
Along those lines...I got a couple stock plates if someone wants to mod their own. :unsure:
294447[/snapback]
If ur on a tight budget, you could do that too. Never done one before. :confused:
my ricky plate was slightly more than snug also. I filed a very fine amount off so it'd fit just right and its great.
modding the stocker isn't hard with a Dremel or similar. Ricky has a pic on his site of his adjustable plate and the markings and you can get approximate advance degree locations from the pic. its like 1mm or so per degree.. along those lines.
ok so maybe I am stupid, but is this mod really worth doing if your motor is pretty much stock? I really have no idea what kind of power advantages you can get from this :shrugani:
294767[/snapback]
Whatcha got done?
