fah_Q Posted December 9, 2004 Report Posted December 9, 2004 When you port an engine do you loose compression? My friend told me that if i ported it i would have to get a new head with some slightly smaller domes. Quote
Duninshee Posted December 9, 2004 Report Posted December 9, 2004 I'm not quite sure if you loose compression, but I had to do it to mine. I had 20cc domes in the cool head and once I had her ported I had to drop to some 17cc domes. You wont have to get a new head if yours is stock. Just have it milled. Quote
SDD Posted December 9, 2004 Report Posted December 9, 2004 If you raise the exhaust port you will lose "kicking" compression but when the motor is actually running if everything is setup correctly you will actually have a gain in compression. Boring out a cylinder a few overbores also will raise compression if you don't recut the head to compensate. Quote
Ducman Posted December 9, 2004 Report Posted December 9, 2004 Like SDD said. You loose static compression when the exhaust port is raised so when you measure compression you will get a lower # but dynamic pressure goes when you get "on the pipe" in the upper RPMs up if done correctly. If you get a fairly top endy port job with high exhaust ports and get real low static pressure, it does hurt the bottom end a lot and can be compensated for somewhat with smaller domes but only to a certain point before the smaller domes start to hurt the top end performance. I had this delima with my 4mm stroker when I first got it going, 125 psi and a top end shaped dome/squish aprox 19cc, I got some new domes fron NOSS, 145 psi more of a midrange dome approx 18cc and it helped the botom end a lot, top end was a little better tool. To answer you question, if you do a mild port then no, if the exhaust ports are raised a lot then you might want smaller domes. Quote
fah_Q Posted December 9, 2004 Author Report Posted December 9, 2004 Yeah, i planned on doing just a mild port job. Thanks for your help. How do t6's perform with a port job, i hear they can be tricky. Quote
