I need help adjusting my chain with my new roundhousing swingarm. I know I have to loosen the two bolts in the back and then I am supposed to put a tool or something in the holes of the left side of the bearing carrier and spin it right. But is it a special tool you need to fit in the holes and I tried using a screwdriver and turning it but it want budge. Does anything else need to be done or what can I do to be able to rotate the bearing carrier.
Right...most carriers will come with the tool, but I've seen people & even myself have used a screwdriver. If it's rusted in the housing it may be a bugger, try sticking a flathead in the gap & pry it open a little bit as you try & adjust the carrier. Hope that makes sense... :rolleyes:
