Ok, I'm having trouble buying parts, because I dont know whats good and whats not. Please list your favorite brand, and maybe list a little reason why you like it. For trail riding.......
Pipes-
Carb-
A arm-
Swinger-
Plasics-
Air Filter-
Shocks-
Axle-
Thanks a ton.
Pipes-PT mids are good ive heard. I know fatties are good for trails Even T5s are good if the trails are not so tight...theres alot of good pipes
Carb- Stock is probably good if your engine is stock
A arm- Quicksand Racing top shelf quality at a low price
Swinger- -1" at least, traction and handling difference is extrordinary. I reccomend Quicksand
Plasics- Im a big fan of Maier. Relatively inexpensive. Fullbore is a waste of money and looks cheesy in my opinion *gasp did he just say that!!!*
Air Filter- UNI filter on a Pro Design flange
Shocks- Elkas. The non adjustable fronts and OEM rebuild for the rear is a fairly inexpensive way to get a very good set of shocks
Axle- LSR Axcalibur, good warranty
Id reccomend to either get the head milled or get a aftermarket head, compression helps alot. Also lighten the flywheel, and get a set of V-Force reeds.
Edited by rebelbanshee2
Pipes-  fattys?
Carb-  35mm 2-1
A arm-
Swinger-  -1?-2?
Plasics-
Air Filter-  K&N?
Shocks-
Axle-
Thanks a ton.
287581[/snapback]
Pipes-FMF Fatties
Carb-trinity 2-n-1 33 or 35
A arm-Laeger +2-+1
Swinger-Laeger -2
Plasics- maier or full bore
Air Filter-k&n
Shocks-Works For $$$$$
Axle-lonestar 2+2
Pipes- topend pipe, cpi, rocket or shearer
Carb- 30mm pwk style carbs
A arm- quicksand +2+1 great guy to deal with exellent product
Swinger- stock now, quicksand when money is avialable
Plasics- stock now, fullbore in the future look bad ass
Air Filter- k&n pods the most air flow
Shocks- works got them in a trade and are great for the money.
Axle- lsr because durablue sucks.
287916[/snapback]
i pretty much agree except for the shocks. i would go with elkas or axis. carbs depending on what you wanna do and what porting you have. if you have more of a bottom end port then get some top end carbs like some 33s or 35s. if you need some more low end then go with a smaller carb like the 28s or 30s.
for the money and the tipe of riding i do the works are fine, if i had the cash i would buy the higher end. maintaining low end is why i went with a smaller carb and they are 100 times better than stock.
Pipes- pt mids or high revs..
Carb- 28mm pwk kiehins
A arm- LSR, Roll Design
Swinger- -2 nothing even comes close to handling like this
Plasics- LAKER CUSTOMS.......THEM BITCHES WERE FREE
Air Filter- K&N
Shocks- TCS SCS Dual Rates
Axle- LSR +2
hope it helps
