joshv5.0 Posted November 19, 2004 Report Posted November 19, 2004 what bore size do i have in my bike? i measured the piston at 65.5 mm is it .060, .080? Quote
DIRTBIKEZ Posted November 19, 2004 Report Posted November 19, 2004 .060 Hope this makes sense. Current bore - stock bore = overbore 65.5mm - 64.00mm = 1.5mm 1mm = approx .039" 1.5mm= approx .060" Quote
joshv5.0 Posted November 19, 2004 Author Report Posted November 19, 2004 .060 Hope this makes sense. Current bore - stock bore = overbore 65.5mm - 64.00mm = 1.5mm 1mm = approx .039" 1.5mm= approx .060" 282594[/snapback] ok when i measured it with the micrometer i got 65.5 BUT the part number on top ends with 6600 and the local shop told me that that means that i have a 66.00mm piston which is .080 i am thinking i should go with the .080 over Quote
DIRTBIKEZ Posted November 19, 2004 Report Posted November 19, 2004 The cylinder bore is more important to you than the piston size. Do you have the tools to measure that? Quote
FIRST BANSHEE Posted November 19, 2004 Report Posted November 19, 2004 .060 Hope this makes sense. Current bore - stock bore = overbore 65.5mm - 64.00mm = 1.5mm 1mm = approx .039" 1.5mm= approx .060" 282594[/snapback] ok when i measured it with the micrometer i got 65.5 BUT the part number on top ends with 6600 and the local shop told me that that means that i have a 66.00mm piston which is .080 i am thinking i should go with the .080 over 282598[/snapback] if i remember correctly the top of your right piston said .060, it was hard to tell in the picture though. Quote
Ducman Posted November 19, 2004 Report Posted November 19, 2004 The cylinder bore is more important to you than the piston size. Do you have the tools to measure that? 282602[/snapback] What he said. Your piston may measure 65.5 but it needs to live in a hole slightly larger than itself. If it says 6600 I'd say that the piston is for a 66.0 mm bore which is a .080" over bore. You might be ready for a big bore sleeve kit soon. Quote
