williamjernigan Posted November 9, 2004 Report Posted November 9, 2004 I am going to purchase a new bearing carrier to go along with my new roundhousing swingarm. Which is better, the tapered or dual-row and what is the difference between the two. Quote
Leadfoot350 Posted November 9, 2004 Report Posted November 9, 2004 Single row weighs less but dual row last longer. Quote
sredish Posted November 9, 2004 Report Posted November 9, 2004 I am going to purchase a new bearing carrier to go along with my new roundhousing swingarm. Which is better, the tapered or dual-row and what is the difference between the two. 278929[/snapback] Buy your carrier from Stan, aka CottenEyedJoe, aka DuneDevilInc.com. Click on the banner at the top of the forum pages and it will take you to him, or send him a pm. You should do this because: 1) He's a site supporter, and we need those. 2) He's a good guy who stands behind his products. 3) His billet stuff is amazingly good looking and high quality. 4) His price is as cheap as you'll find anywhere, including Ebay and it's equal to products twice as expensive. 5) Because lots of people have used his products without problems. 6) Because we'll hunt you down and take you out... Ok, worth a shot anyway... Just go to Dunedevilinc.com or click the Dune Devil banner at the top of the screen. Quote
boonman Posted November 10, 2004 Report Posted November 10, 2004 Alright, a tapered bearing, is just like a wheel bearing on your car. Well, like bearings used to be anyways. Not those chincy sealed bearing unit assembly's that are found these days on most new shit, I'm talkin about old school bearings, where you can pry the clip up, remove the nut, pull the spindle off, pull the tapered bearings out, and grease them. Make sure you have Adobe Acrobat reader, or a way to view PDF's, and CLICKY CLICKY It will show you all the different bearing types.... Quote
rebelbanshee2 Posted November 10, 2004 Report Posted November 10, 2004 the taper bearings are superior in side load strength....but you loose a TON of chain adjuastment with them because the are a larger diameter than the ballbearings so it isnt worth it for that. You cant even change one tooth on the countershaft with one Quote
