Mod Banshee Posted November 4, 2004 Report Posted November 4, 2004 What will the top speed of my shee. It has Passion 12 Port Stroker kit 33PWK's Boss Intake Cool Head w/21cc doms FMF Fatty Pipes & Power Core 2s V-Force Delta 2s Team Alba Clutch Kit Hinson Clutch Basket Hinson Cushions Hinson Pressure Plate Lightened FlyWheel Vitos Degree Key Pro Flow Intake 6 Filtered Air Vents 16 tooth Front Spracket 39 tooth Rear Spracket Quote
racer Posted November 4, 2004 Report Posted November 4, 2004 go to bluetraxx i think. there is a calc on the net somewhere that wil tell you if you accurately put in the correct numbers. maybe do a search or something Quote
banshee04le Posted November 4, 2004 Report Posted November 4, 2004 That gearing is basically equivalent to a 17 up front with a stock rear. What size tires? I'll guess 87mph with 22" tires if you can pull it through the top but I'm sure someone will set me straight. Quote
PUSH THE THROTTLE Posted November 4, 2004 Report Posted November 4, 2004 91 at around 8500 rpms with 22" tires. With the stroker motor you could pull more than a 16 up front. Quote
MudSlinger09 Posted November 6, 2004 Report Posted November 6, 2004 (edited) i heard this works pretty well if you tie a chain to a tree and connect it to your swingarms and gun it , you`ll get a fat speed boost , eh im just being an asshole id agree with push the throttle Edited November 6, 2004 by MudSlinger09 Quote
Blue Duece Posted November 6, 2004 Report Posted November 6, 2004 1 tooth up front =3 in the rear....so your two thirds of the way to a 17/41.........with passion juggs ill bet it pulls pretty hard....maybe a 100mph if ya pinn it and hang on Quote
racer Posted November 6, 2004 Report Posted November 6, 2004 proquad, i think it was, thought his 12port 4mil would reach about 100. correct me if i wrong. Quote
