ok I went to ris and weighed hubs,sprocket holder and rea brake hub and if you buy all of that for 475 you will loose about 4 lbs. There stuff is the best in my book, the rear hubs are nice and they include really nice nuts, also the rear sprocket holder is straight like the stock one. I dont like lonestars twisting style. You can also get a new rear wave disc that will shed some weight but all that will be about 600 with tax and shipping and weight about 4-5 lbs less. Is that worth it? Will you be able to feel that or should you spend that on your motor? The only thing I can do to mine is stroke it 4-7mill. Be carefull of some brands of alum stuff. I read that shark front hubs are 10oz each heavier that stock. Both is 20oz more and that is horrible. You can sent the stock fronts to jj&a and they can cut out the center section. Check out their website on it for a picture.
