XfiveGEE Posted October 14, 2004 Report Share Posted October 14, 2004 Every now and then my throttle will get stuck in a high rpm. It's pretty scary! .. I have to slam the brakes or tap the thumb throttle in for the high revs to stop. I recently got my bike rejetted w/ pipes, reed valves and a cool head. This didnt happend before all the mods. Could this be the problem? Or could it be a messed up wire or sumthing Also, will a YFZ throttle work on the Banshee? .. I'm sure it will ... I just like how looser the throttle is. Any help will be great. Thanks for reading. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted October 14, 2004 Report Share Posted October 14, 2004 Every now and then my throttle will get stuck in a high rpm. It's pretty scary! .. I have to slam the brakes or tap the thumb throttle in for the high revs to stop. I recently got my bike rejetted w/ pipes, reed valves and a cool head. This didnt happend before all the mods. Could this be the problem? Or could it be a messed up wire or sumthing Also, will a YFZ throttle work on the Banshee? .. I'm sure it will ... I just like how looser the throttle is. Any help will be great. Thanks for reading. Does it happen only when it's wet or been washed Quote Link to comment Share on other sites More sharing options...
ranshee Posted October 14, 2004 Report Share Posted October 14, 2004 Does it have dual carbs. Quote Link to comment Share on other sites More sharing options...
sredish Posted October 14, 2004 Report Share Posted October 14, 2004 Simple, pull em and clean em. Quote Link to comment Share on other sites More sharing options...
XfiveGEE Posted October 14, 2004 Author Report Share Posted October 14, 2004 Does it have dual carbs. yes it does Quote Link to comment Share on other sites More sharing options...
mat Posted October 14, 2004 Report Share Posted October 14, 2004 Do you have the Toomey TORS removal kit? If so, you may have your throttle cable adjusted incorrectly. If the slides get pulled too far up they can stick in the gasket for the carb tops. This will only happen at full throttle. Quote Link to comment Share on other sites More sharing options...
BenBB Posted October 14, 2004 Report Share Posted October 14, 2004 Every now and then my throttle will get stuck in a high rpm. It's pretty scary! .. I have to slam the brakes or tap the thumb throttle in for the high revs to stop. I recently got my bike rejetted w/ pipes, reed valves and a cool head. This didnt happend before all the mods. Could this be the problem? Or could it be a messed up wire or sumthing Also, will a YFZ throttle work on the Banshee? .. I'm sure it will ... I just like how looser the throttle is. Any help will be great. Thanks for reading. Does it happen only when it's wet or been washed Oh sure rub it in Rod mine still does it on occasion but since I've threatened to get some 28's she's let me hit a few puddles without tryin' to kill me again... X5G getting the carbs wet will often cause them (or just one) to stick wide open, nobody's sure exactly why. I've also had one stick when the little guide for the carb slide turned, but that's probably not your case since you can stab the throttle and get it to quit. Oh and a 450 throttle may or may not make any difference, since you're still pulling two carbs... Quote Link to comment Share on other sites More sharing options...
XfiveGEE Posted October 14, 2004 Author Report Share Posted October 14, 2004 Yeah its just at the highest RPM's when it sticks ... I've only notice this happen in 1st and 2nd gear. Carbs are always dry unless I clean my bike. I guess I'll fiddle more w/ the cables ..ect. Quote Link to comment Share on other sites More sharing options...
Capone Posted October 14, 2004 Report Share Posted October 14, 2004 Airleak? Just a thought. Quote Link to comment Share on other sites More sharing options...
XfiveGEE Posted October 14, 2004 Author Report Share Posted October 14, 2004 were would an air leak take place at? Quote Link to comment Share on other sites More sharing options...
Capone Posted October 14, 2004 Report Share Posted October 14, 2004 Get a can of carb cleaner, spray around every gasket while its running, listen for your shee to start revving. Also, my throttle cable broke where the cable splits into 2 to run to each carb, I heard they break there frequently. Quote Link to comment Share on other sites More sharing options...
Wallynut Posted October 15, 2004 Report Share Posted October 15, 2004 Do a search on "water" or "stuck carb", you will find this is a common problem. No great cure neither, heres 4 solutions: (1) put TORS back on(2)buy different carbs(3)avoid water in colder weather, (4) or just deal with it. Quote Link to comment Share on other sites More sharing options...
Capone Posted October 15, 2004 Report Share Posted October 15, 2004 I dont think I've heard someone ever suggest putting the TORS back on Quote Link to comment Share on other sites More sharing options...
KRMit Posted October 15, 2004 Report Share Posted October 15, 2004 I've never experienced the "water problem" but wouldn't it probably only cause one slide to stick? I'm sure both could stick at the same time but it's unlikely and surely won't happen everytime. If both slides are sticking at the same time it's probably your cable but could also be your throttle housing if you've gotten anything stuck in there. A temporary fix would be to lube your cable, but you might want to replace it. My throttle used to stick sometimes and changing the cable did the trick. If only one slide is sticking it could still be the cable but is more than likely something in that carb. Specifically somewhere with the TORS assembly or slide. If you can't tell whether it's both or one carb clean both carbs real well, then possibly replace cable. I hope I've helped. It's really late and I'm tired. Quote Link to comment Share on other sites More sharing options...
svtkid78 Posted October 15, 2004 Report Share Posted October 15, 2004 Throttle cable needs some mo' free play. Quote Link to comment Share on other sites More sharing options...
