Bongshee Posted October 4, 2004 Report Posted October 4, 2004 Im looking to get a set of carbs to finish off my bike, and im kind of stuck on what to get. I want to stay with a stock size...or maybe jump up another size or two. My bike is pretty much stock except for pipes and intake. I have come across keinin and mikuni......which is better?...and how much difference does it make with or without the TORS removed? Thanks Quote
banshdog Posted October 4, 2004 Report Posted October 4, 2004 I dont have much info on the brands of carbs, I would recommend definately going larger than stock though. Also the TORS.... The bike should run the same either way. Benefits of removing it are: removes clutter for easier work on carbs, weight (If your counting it), one less possible problem down the line (if the TORS fails, you wont be riding)..............yada yada Quote
racer Posted October 4, 2004 Report Posted October 4, 2004 maybe some 28mm's they seem to be pretty popular. Quote
sredish Posted October 4, 2004 Report Posted October 4, 2004 Depends on what your going to do later on. If your just gonna leave it stock with pipes, then the stock size are fine and honestly, I wouldn't spend my money on new ones, just get the TORS removal kit and be done with it. If you have plans on porting, then get some 28's. Unless your stroking, there's no need for anything bigger than 28s. Quote
racer Posted October 4, 2004 Report Posted October 4, 2004 Unless your stroking, there's no need for anything bigger than 28s. really? what about bored stock carbs, would that surfice? Quote
sredish Posted October 4, 2004 Report Posted October 4, 2004 Unless your stroking, there's no need for anything bigger than 28s. really? what about bored stock carbs, would that surfice? Stock carbs are usually bored out to 28mm. So, there ya go!! Quote
racer Posted October 4, 2004 Report Posted October 4, 2004 Unless your stroking, there's no need for anything bigger than 28s. really? what about bored stock carbs, would that surfice? Stock carbs are usually bored out to 28mm. So, there ya go!! i could keep that sleeper illusion then. Quote
