Bongshee
Everything posted by Bongshee
  1. YOU DA MAN!!!!!!!!!!!!!!!
  2. I just removed the stock carb tops and now am wondering what do i do with the plugs left over from the old "brains".....im pretty sure they are what is affecting my bike right now.... CHEERS
  3. http://www.bansheehq.com/forums/index.php?showtopic=35043 Theres info from top to bottom of the page....good sites and also a page on how to check your plugs CHEERS
  4. oops gotcha.....290
  5. Im just going to let you guys know what i have on my bike as of now...and make this as simple as possible...just curious on what someone with the similar setup is running. 2002 Bansh Sea level FMF gnarleys Airbox removed with toomey filter wiseco prolites (stock) TORS removed Stock carbs Currently Main is 190, needle at clip # 2, pilot 25, air screw 1.5. CHEERS!
  6. I heard a rumor that Yamaha is changing the Banshees plastics for '06.... Apparently they are FINALLY going to change its look... Anyone else hear this? Cheers
  7. I have a set of carbs coming that have had the TORS removed. So now that ive gotten rid of them , will my old Motion Pro twist throttle work with the tops????..... Cheers
  8. Anyone know the BEST website to buy custom banshee parts. Im looking for bars, perches, fancy replacement parts and all that sh!t...... Cheers
  9. Does anyone know THE BEST online banshee custom parts store???? Im looking for bars, perches, filters, billet parts...etc... Cheers
  10. Nice.... Thanks for the pics boyz....
  11. I am looking to do a little suspension mods to my Shee.....I plan on shortening my swingarm to a lonestar - 1"....and widening front and rear. my rear about 1.5" with a Durablue axle. For the rest i wouldnt mind using Elka shocks and lonestar A-arms. Sounds $$...but this is my first choice. If anyone here has gone thru this and would like too give me your opinion or let me know what you did...i'd be more than glad to read it....... Im a pretty agressive rider and want something tough and able to handle a good sh!tkicking....and, a good bang for my buck as well. CHEERS....
  12. Vancouver Island, British Columbia!!!!!! Cheers
  13. I am going through my third rebuild and just like the other two my cause for rebuild is a faulty filter. I started out with dual k&n's...they would constantly fall off because of tthe hose clamps...and were not too airbox friendly. I then jumped to a foam uni filter.....once again..it was not very airbox friendly and it ended up soaking up alot of sand. So now i am looking for THE BEST setup for air filters. I rarely do any dune riding....alot of trail and sand pits.... It is also very wet here....so do i go foam or the steel mesh design???? Any ideas?...... right now i am looking to a K&N single fiter with pro design adapter sitting in a stock airbox...yay or nay? Cheers
  14. Im too cheap too buy polished/chrome add ons to my bike right now...does anybody know or have they polished up there own banshee parts too look just like a aftermarket addon. (clutch cover, carbs,shifter,etc) Let me know .... Cheers
  15. Im looking to get a set of carbs to finish off my bike, and im kind of stuck on what to get. I want to stay with a stock size...or maybe jump up another size or two. My bike is pretty much stock except for pipes and intake. I have come across keinin and mikuni......which is better?...and how much difference does it make with or without the TORS removed? Thanks
  16. Has anyone used these before?.......I am looking to widen my rearend without having to spend all the $$ on a a durablue axle. What do you guys recommend for spacers?.......3", or 5" Cheers
  17. CARBS NOT CRABS....
  18. Im looking to buy crabs...now im looking for stock ones with the throttle body top style...i have also seen Mikuni's with the cap top. Now, is that there way of eliminating the bulk of the carb, and does it work jusat as well for throttle action as a stock one does?
  19. Thnaks...i will look into that.... How much???
  20. Im looking to clean my bike up a bit so i can powdercoat my frame. What is involved in cleaning up my wiring hareness a bit and eliminating the wires that provide power to Brake lights, ignition etc. Will it affect anything and is there a a safe place to start at? I no longer have any use for half the electrical....just looking to clean up its appearance.
  21. I am Looking for a COMPLETE set of carbs (with tops) for a 02 Banshee.......in good shape....as well as a stock airbox. If Anyone is selling a K&N kit with adapter plate i will gladly take that as well.... Need ASAP Cheers
  22. Looking for a COMPLETE set of carbs (with tops) for a 02 Banshee.......in good shape....as well as a stock airbox. If Anyone is selling a K&N kit with adapter plate i will gladly take that as well.... Need ASAP Cheers
  23. I am very interested in the stock Carbs....are they complete? Just reply back with a price and i'll tak'em off your hands... ~ Cheers
  24. Can you possibly hook a canadian up with a complete set of carbs and a stock airbox? ~ Cheers
