bansheewizard Posted September 23, 2004 Report Posted September 23, 2004 just the other day i took my boost bottle off ,if i leave the hole open will it hurt, and if so whats a good thing to stop them up with. Quote
bigboybanshee Posted September 23, 2004 Report Posted September 23, 2004 Do not leave the hole open unless you like to rebuild top ends...You could plug them up but I hear it's harder to tune with no balance tube. If you don't like the boost bottle, I'd recommend using the stock balance tube again, but don't leave the holes open...just think of what would go into the holes when you ride if they were open Quote
bansheewizard Posted September 23, 2004 Author Report Posted September 23, 2004 will a stock balane tube fit the pro design air intake Quote
SICK BOY Posted September 23, 2004 Report Posted September 23, 2004 It should fit,but if not make a balance tube out of 1/2" PVC. Quote
Proquad101 Posted September 23, 2004 Report Posted September 23, 2004 I use cane tips with hose clamps. You can buy the cane tips at walmart in the pharmacy department. You will get better throttle responce but you will have hell trying to get your bike to idle. Quote
J.J. Posted September 24, 2004 Report Posted September 24, 2004 I use cane tips with hose clamps. You can buy the cane tips at walmart in the pharmacy department. You will get better throttle responce but you will have hell trying to get your bike to idle. Proquad101, it sounds interesting, but please pardon my stupidity, what the hell is a cane tip?? Quote
ehall1 Posted September 29, 2004 Report Posted September 29, 2004 i think he's talkin bout them rubber things that go on the bottom of canes and crutches Quote
bansheewizard Posted September 29, 2004 Author Report Posted September 29, 2004 ok i took it off and pluged them and that damn banshee want wind out in 6th now cuz its loading up so bad back on with the boost bottle Quote
racer Posted September 29, 2004 Report Posted September 29, 2004 yeah, there isnt really any reason to remove one unless you get one of them boss intaked with the built in c-tube. if it came with the bike id just leave it there. Quote
00BANSHEE Posted September 29, 2004 Report Posted September 29, 2004 I think I have a stock crossover tube laying around somewhere. If I can find it and you PM your address I'll send it to you. Quote
the boris Posted August 28, 2019 Report Posted August 28, 2019 I just took mine off and plugged it in, tomorrow we shall see if i can tune it correctly. Sent from my ONEPLUS A3000 using Tapatalk Quote
