I changed the oil today and now I'am able to shift through all 6 gears without pulling the clutch handle. What could possible be the problem? Its a brand new Barnet with about 50 hours on it. Thanks for any help.
there is no problem, you should be able to do clutchless shifting. i do it all the time on every bike and quad i own.
Same here. A lot of people don't pull the clutch to shift.
it's called floating the gears. I do it in my spare work truck all the time so I dont have to double clutch it.
Did you change the type of oil you were using? Have you changed the oil since you put the clutches in? I know the factory 10w-30 they throw in it makes it hard to clutchless shift, as soon as I threw in the Honda semi synthetic oil, shifting became smooth as butter.
