Hey guys, I need a little help with my girlfriends Blaster. Its pretty much brand new and has only been ridden a few times. Everything on it is completely stock. Lately when we have gone riding she says that it hesitates in each gear. Its like its got carbon build up and then it runs fine once you burn it off but I took it for a little test ride last time and noticed the thing was gutless. I know I might have just been used to my banshee but it really did seem to have about half the power that it used to. It is a 2001 and might have 5 good rides on it. Please help me out so I can get it fixed before this weekend. Thanks a bunch, Mike
I have gone to that site but have never found any forums on there. All I find is pictures. Banshee haters? thats horible heheheh. thanks again.
Thanks guys, for some reason I still cant find a forum on the blasterhq and I cant register there because it wont send me the activation email. Anyway I tested the compression today and it was 115psi. Is that low? also spark plug looked good and so did the air filter. I got some 110 octane gas and am going to see if that will help any. If anyone can think of something that might be causing the blaster to run poorly please let me know. Thanks again.
I agree with fro on this. Clean the carb good. As far as hesitation goes, try adjusting the a/f screw. Also, with only 115 lbs of compression, I wouldn't waste your money on using 110 octane fuel. It will not benefit from it in any way.
115# of compression is LOW, you might pull the head and have a look. Also, the lower the compression the lower octane rating you need, not the opposite.
The best and really only way to make a Blaster seem like it has more power is to follow these three easy steps.
1. Rent a small vehicle storage unit for exactly 2 years 115 days and lock the Banshee in it without looking at or thinking about it for the entire time.
2. The only method of transportation for the period of time in step 1, other than walking, a unicycle and if you can't ride one you may substitute a big wheel, and of course the Blaster.
3. The most important step only ride the Blaster down hill at max speed.
