Sheeboy12 Posted August 24, 2004 Report Posted August 24, 2004 Just wondering, i know how everything works and after 2 1/2 tanks i just couldn't control my self any more. I figured that the rings were already seated. Quote
Banshee~ Posted August 24, 2004 Report Posted August 24, 2004 Just wondering, i know how everything works and after 2 1/2 tanks i just couldn't control my self any more. I figured that the rings were already seated. Its very important ....2 1/2 is good. I let loose after the third Quote
d3xnij Posted August 24, 2004 Report Posted August 24, 2004 is it as important with a 4stroker ? Quote
nickxc Posted August 24, 2004 Report Posted August 24, 2004 they say its oposite on a 4 stroke... Ive been told that you should go right out and pound on a 4 stroke and baby a 2 stroke . I really dont know for sure but someone can post a site that has all the info you need (I just dont remember what it was or Id post it myself)... oh ya and I think your fine after 2.5 tanks HIT IT!! Quote
SICK BOY Posted August 24, 2004 Report Posted August 24, 2004 I ussally baby it for the first tank,and then ride it normal. Quote
fixitrod Posted August 24, 2004 Report Posted August 24, 2004 I agree. You were probably broke in after half tank if you did warm up cycles. Quote
PyRo_ZaCh Posted August 24, 2004 Report Posted August 24, 2004 when i first got my drit bike (ttr 225 4stroke) they said just not to excessivly do high rpms, and its good to do an oil change right after break in because i found lots of metal shavings in there Quote
2Smoker Posted August 24, 2004 Report Posted August 24, 2004 It says in the clymer manual to run it at 16:1 for a bit and let it warm up and drive it around a little not revving it, then drain gas and put 24:1 in it and drive it a bit not revving then let it cool down and start it back up and start hitting the powerband. It doesn't say how many tanks of gas, but 2.5 should be ok as long as you aren't really gunning it. I just got mine bored and when I get the crank put back in and put together I am going to baby it it cost too much to fix it this time to be cranking on it during important break in time. Quote
