stockridinshee Posted August 11, 2004 Report Posted August 11, 2004 ever since a few weeks ago my banshee hasnt been runnin good at all it wants to bog down really bad. it seems like it does it more when im going at a constant speed. when i get in higher rpms it seems to do fine untill i start going a constant speed again. its hard to explain but any help at all would be highly appreciated thanks Quote
sredish Posted August 11, 2004 Report Posted August 11, 2004 probably cause your letting out the throttle to a "constant speed" and your jetting in that throttle area is a little off. has the weather changed recently? like colder or hotter? colder would lean it out some and and hotter would richen it some. i'm betting that you might need to adjust the clip on your needle. is it flat bogging or is it sputtering at all? Quote
stockridinshee Posted August 12, 2004 Author Report Posted August 12, 2004 its hard to explain what it does it does kinda sputter down and when im riding it feels like im putting the brakes on and off really fast. like it jerks kinda... i duno i cant explain thats the best i can do but the weather hasnt changed. thanks alot Quote
stockridinshee Posted August 16, 2004 Author Report Posted August 16, 2004 i checked the parking brake and the tors and put new plugs in and im still having the problem any other ideas. it does it in every gear and in neutral if that helps any. im very new to banshees and i guess any thing to do with motors i do know some stuff but not too much. i dont think its my jetting because it just statred out of no where, but again i dont know to much. thanks a lot for the help. Quote
excalibur Posted August 20, 2004 Report Posted August 20, 2004 pull the spark plugs out and see if they are burning the same. this will let you know what side the problem is on. Quote
stockridinshee Posted August 21, 2004 Author Report Posted August 21, 2004 checked the plugs and there both the same. Quote
bansheeboy2004 Posted August 21, 2004 Report Posted August 21, 2004 is it like when you rev it up even in neutral it starts to then it starts poping and running like crap Quote
stockridinshee Posted August 22, 2004 Author Report Posted August 22, 2004 no it dosnt sound liek its running bad it just feels like it. Quote
pimpeinkc Posted September 13, 2004 Report Posted September 13, 2004 i would check your air filter. if that isn't it measure the resitance in your spark plug caps, if they are the same you should be fine there" sorry don't feel like lookin the resistance up" make sure your fuel is flowing and your floats are set and working properly. other than that there isn't may things that would cause this. Quote
