im running t6 pipes no snorkel uni filter rad valves and the toomey jet kit, i was told by the yamaha shop that i needed to go larger on the mains, its got the 280 in but im running lean, and also 30 on the others give some advice please
mains you can get at MagicRacing.com or Carbparts.com. Pilots need to come from the dealer generally, because their banshee specific. and i'd get rid of that Toomey needle and go back to the stocker.
Edited by sredish
i thought i needed bigger than the stocker
in regards to your needle, it doesn't work the same way as your jets, it's more taper, diameter and length, not "bigger". I could go into great detail about how the needle affects things, but it's much to complicated to go into right now, too early.
Basically, from my little experience, the Toomey needle (which is just a Blaster needle) just doesn't seem to work well in the banshee. I've seen a lot of people come through here having a tough time getting there jetting worked out and they're using the Toomey needle, and quite a few come back to update that they removed the Toomey needle and ran the stocker and it's been great since.
Just my views.
Edited by sredish
get jets from proflo.com. they are the cheapest and best place i have found to deal with so far. i heard carbparts is a bunch of idiots, but i dont know from personal experience
