If I put the wrong plug wire on the plugs will it make a difference?????
I dont know which one came off which side. I didn't find a pic of it in my clymer or anythign that really tells me. anyone wanna look at their shees for me and tell me which plug cap you have on which side??
if you switch them your banshee will fire on the wrong order meaning 6 gears of reverse.....
jk. i dont think it matters, but id keep them on the same deal. if all else fails, try them both and see which way runs better.
It doesn't matter which one goes where.
The reason why (for those that may not know) is they both come off of one coil, and there is only one pick up on the fly wheel. You would need a distributor or a crank triggered ignition with different lugs for firing the appropriate cylinder.
Its just easier to fire them both every 180 degrees of crank rotation.
If you want to put it back on the way it was, take the longest plug wire and connect it to the left side plug(if you were sitting on it) and the shorter wire on the right side.
