German Shepherd Posted July 5, 2004 Report Posted July 5, 2004 Will the tors system kill my motor if I hold my banshee flat i.e. Wide the F open in 1,st, 2nd, 3rd, 4th, 5th, or 6th gear for prolonged periods? as in keeping it in 3rd or 4th all the way up the hill with the throttle pinned?Thanks Quote
locogato11283 Posted July 5, 2004 Report Posted July 5, 2004 no it will not. word. im not even sure the TORS works properly. its never shut my bike down or anything, and ive had it pinned on long hillclimbs for what it seems like forever. Quote
NYUK Posted July 5, 2004 Report Posted July 5, 2004 the only thing the tor s did on my bike was make it stick wide open in the snow. Quote
Cotton eyed Joe Posted July 5, 2004 Report Posted July 5, 2004 TORS bascially consists of 4 switches. One is on the parking brake lever One is on the thumb throttle One on each carb Basically they are ignition interrupt switches. If the thumb throttle switch gets connected (it makes contact when released) and one of the carb switches don't connect it chops the ignition. It really has nothing to do with how long you hold it wide open. It has everything to do if your carbs STICK open, and you release the thumb throttle. Quote
. Posted July 6, 2004 Report Posted July 6, 2004 mine likes to not make my bike idle and down low it is real choppy, and then I'll hit a bump and it'll go back to running smoothly, and then I'll hit a bump further down the road and it'll be back to choppiness and not idling......That little black box has to goooooooo Quote
