Getting rid of stuff
I just pulled apart the last of my parts banshee and I'm tired of looking at this other stuff laying around here.
So to start with I have...
Chrome T5's with or without stingers and silencers.
2- Radiators
Gas tank with new inserts
Coil
Factory kill switch
Wiring harness with lights cut off
Left hand Cylinder. Right hand may be salvagable. You get 2 for 1 :)
Head undamaged
Clutch side engine cover... SOLD
Airbox lid drilled
Tranny gears
Shift drum
Shift forks
Shift shaft
Clutch arm
Clutch basket Worn but still usable
Kicker gear
Early swingarm
Early Axle with carrier and sprocket
1- upper left Jarm
2- Lower A arms tight ends a couple dings and need a paint job
Red Maier rear fender with some scuffs no cracks
Light grey tank plastic and rad cover
Purple front and rear fenders in bad shape... good for painting or cutting or practicing on.
Front master cyl
Early rear master cyl, caliper, brake pedal,
NEW +12 stainless brake hose
Steering stem seems pretty straight
factory bars with purple Renthal pad
tie rods 1 or 2 bad ends
J arm frame if I sell it as is great but I may modify it for A arms while I can and get a few more bucks for it.
Tires, tires, tires
2002 Blaster I'm going to part out. Right now it's whole.
I really just want to move this stuff so make me an offer... I'll probably take it.
I will have pics of everything later today.
DO NOT PM ME!!!
If you have questions, post them here or email me at IHRbearings@peoplepc.com
Edited by Holyman
The intake boots are $8 shipping included.
The tranny is just the gears. The cases were blown apart. I do have an upper case that was damaged from a thrown chain but did not get to the innards. I have the lower case to match which has about a 1/2 hole in it. I ground out the area to make sure it's not cracked beyond the hole. It looks tight.
The Blaster was running fine until it locked up. I'm sure the oil injector went bad because we rode it all winter with no problems. So I really doubt it's an air leak or jetting. Either way the Blaster iscomplete and has a title. I also put Hydro rear brakes on it.
The cylinders are bored to 64.10 as far as I can tell. The right hand jug has a chip in the bottom from the rod that snapped. It may be salvagable.
I will have pics later on tonight.
Email me if you want pics.
Keep an eye on the first posting. I will be editing it with stuff that sells and stuff that I am adding to the list.
Edited by Holyman
how much you wanting for them T5's?
I'd like $275 + shipping for the t5's.
What condition is the clutch cover in? price too
The cover is in OK shape. There is a groove where the brake lever was rubbing. $25 +shipping.
got any silver rims in good condition that will either fit 22x11x9 rears, or stock fronts?
I have some silver rims but I want to keep them unless you have some other rims and some $$.
the tie rods with damaged ends, which ends are damaged? I am needing a good outter end
Do you need the end that is right hand thread or left hand thread?
Edited by Holyman
I've got gold ones for rear... They are perfect, just gold..
How much?
I believe the outters have the LH thread
Edited by Fox73-Zz
