am in the processes of installing +2 front a-arms on my shee, my friend is selling me some brand new works shocks that came with a +2 a-arm kit for a Raptor, will those fit my new a-arms on my banshee?
They may "fit" but they will not be correct for your banshee. Valving and spring rate will differ from a raptor to a banshee due to the differences in suspension geometry. I would suggest that you get a set of shocks for your application. Just because something fits does not mean that it will work / perform correctly.
if i were you i wouldnt listen to DUNEDEMON, he doesnt know anything about shocks, spring rates, travel and that sorta thing. :P just messin with ya DEMON. he does know his shit about springs so id take his advice. hell i dont think id try and put raptor shocks on my banshee. now yfz450 shocks, thats a different story.
thanks guys, thats why i had to ask here first. since there the same lenght and adjustable i wanted to make sure. i was actually trying to get some yfz450 shock but had no luck (and not much $$$) :cry: i guess i just have to use my stock ones for now, how will those performe?
of course you could find out the overall length of thecraptor shock and if its the same as the shee. your in like a burglar......but works shock suck....and knowing works thay are the same....... :whoa:
what kind of shocks do you guys recomend i use? my bike only thouches sand so i like to play in the bowls, on hills and fly thru the woops, i dont want to spend to much $$$ cause i still have to get a rear axle banghead
  • 2 weeks later...
I have a set of dual rated works shocks on my beanshee with +2 +1 a arms on my quad and they are great, alot better than the stock ones!
